I need help purging out a pesky CAD file that is lingering in the background of our office template and getting brought forward into any file using this template. I've downloaded 4x add-ins, ran 3x dynamo scripts to purge Imported dwgs, which did nothing.
This is the cad file at hand. Note I deleted all the layers out hoping I can delete the subcategory afterwards (which you can't)
Second image is of the object being selected (which tells me it's not nested in a family..) I can't delete it by hitting delete or find it in a view.
Anyone run into this kind of issue before? I'm exasperated and am out of ideas.
try with Dynamo..
I managed this for CAD imported using this simple script...in order to delete all the imported instances,, This was done in Revit 2024
Constantin Stroescu
..and you if you want to choose a certain imported CAD file to delete :
Constantin Stroescu
