I have a sheet group set up with about 40 or so sheets for a submission I will be making soon. When I go to print, under selected views/sheets, there does not seem to be a way to select the sheet group, and I need to select sheets individually. Is there a way to select group instead?
You need to select the sheets for a group, save as a Set, then print. Next time you can just pick that set from the dropdown and print.
To my knowledge unfortunately Out of the Box you have found exactly how to do it. Save a sheet/print set and it will be there for future use, but would need to be updated if sheets are added. Alternatively if you download pyRevit there is a way to print based off of schedules in the project, not only will it print based on the filter but it will also print in order.
