How to plot/export to PDF & setup plot style like in Autocad
9 ANTWORTEN 9
Nachricht 1 von 10
Mat.Syaf
696 Aufrufe, 9 Antworten
Is there a way to print/plot/export to PDF from Revit sheet and setup plot style like we plot in the Autocad ?
The only choice when I want to print to PDF is as color, black line or grayscale. I want some color to be in black and some color to be colored as the layer.
Thank you
Beschriftungen (5)
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: Mat.Syaf
VGOs not working for you?
Revit prints what is shown on the screen (a.k.a. WYSIWYG).  Only thing is Thin Lines. Revit doesn't print a Thin Line View as it looks.  Output uses actual Line Weights.
Nachricht 3 von 10
Set your object styles to show exactly what you want your print to be then that is what your print going to be.
Nachricht 4 von 10
Mat.Syaf
als Antwort auf: barthbradley
I have tried change the VGO, but nothing change. For example, specialty equipment family with red line color, I change it to black (change in VGO), but the color is still red. or am I do it wrongly
Nachricht 5 von 10
Mat.Syaf
als Antwort auf: ToanDN
but I have another sheet that need that object color to be grey color. In my case now, my object color is red. In some sheet, i want it to be black and for another sheet, I want it to be grey. If I change the object color, then the whole sheet will be the same right?
Nachricht 6 von 10
I suspect you have another Override in place that has hierarchy.
Element Visibility Override Hierarchy | Revit 2019 | Autodesk Knowledge Network
Nachricht 7 von 10
If the colors are not universal for the entire project then you need to modify them via view templates or view's visibility graphics overrides.
Nachricht 8 von 10
Mat.Syaf
okay I will go through that hierarchy. 1 more question, how to change the text and hatch color from the family? what I understand is VGO can change the color of line.
Nachricht 9 von 10
Via Filters.
Nachricht 10 von 10
Mat.Syaf
I don't really understand how Filters work. Does it can change Generic Annotation color? I used Generic Annocation in the Specialty Equipment family.
