How to plaster the bottom of a Slab Edge?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
559 Aufrufe, 2 Antworten
Hello. I have this slab edge on the first floor of my project. I would like to know how I would add a plaster beneath it just like the one I've made in AutoCAD from the photo below or the attached photo. I hope you can help me. Thank you.
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Depends on the level of details you want to achieve. If it is purely 2d
presentation the you could use cut profile tool in a view. If you need the
actual 3d model then you could draw a thin ceiling and join geometry. You
could also place another slab edge below the existing one, with a thin
profile, an offset distance, and plaster material, then join them.
Nachricht 3 von 3
als Antwort auf: ToanDN
Thank you. I'm just starting to learn Revit and I didn't know there's a limitation to what I want to achieve in 2D presentation unlike in AutoCAD. :leicht_lächelndes_Gesicht:
