I am newbie to Autodesk software and need to create a BIM project involving placing steel stair,
looking for details steps to place steel stair over a hill side topo surface.
Thanks!
Before you look at the specifics of your project- ie stairs and toposurfaces, you'll need to get (at least some) familiarity with the basic- ie Levels, Views, Navigation, etc.
And then there is the issue of the stairs- how complex are they?
These short vids may help to get you started...
Hope these help
..to elaborate further, we would also need to understand the design intent. What do you envision when you say steel stairs over topo surface?
Hi @Anonymous,
In my opinion, if this is my job:
Firstly: I will sketch and imagine how the steel stair will be constructed on the site from the beginning to the end of the project.
Secondly: After I have all necessary informations about the construction processing of steel stair then i "ask" Revit something like that: How i can create a foundation for steel stair ? How can i create a steel colum ? How can i create a steel stair based on that conditions? ...
Thirdly: Try to search more and more tutorials on websites about steel stair....
Just for your reference, sorry if my English is not clear
...also the stair doesn't care about material. Steel, Rubber, Cloth...it doesn't matter. ![]()
@Anonymous: I think I know where you're getting stuck. Here's the concept: Don't worry about the Toposurface. Forget about it. Just draw your Stairs and then go to a Section Cut View (cut through the middle of the Stairs in Plan View), and move the Toposurface up or down into the best position relative to underside of the stairs. You may need to repeat this several times, with several iterations of your stair landing heights, but you get there eventually.
That's the simplest workflow I can think of. Keep in mind also, that riser height and tread depth (rise and run) are governed by Building Codes, so there's not going to be a lot of wiggle room in stair's rise and run (e.g. its slope).
