How to Place decal in a family?
4 ANTWORTEN 4
Nachricht 1 von 5
1201 Aufrufe, 4 Antworten
I am putting decal  as a material in my family and when i  apply it to my family it is visible (only when tiles feature is on. Horizental/vertical tiles are on). But when i turn off tiles my image is not visible. Can anyone help regarding this?
4 ANTWORTEN 4
Nachricht 2 von 5
ennujozlagam
als Antwort auf: Anonymous
hi, here is the solution in previous thread. hope it helps. thanks
Click HERE
Click HERE
Nachricht 3 von 5
als Antwort auf: ennujozlagam
Thanks for help but my problem is still there. i followed the same steps but when i turn of tiles  (vertical/horizental) my image is not visible. I need to know that specifically what will be the solution for this case. I hope this makes sense.
Thanks!
Nachricht 4 von 5
ennujozlagam
hi, This is from Alfredo Medina advise
"Try with the "Decal" feature. It works within the project only, not in the family editor. First you create a Decal type with your desired image, then you apply the decal type to the faces of objects in the project."
Nachricht 5 von 5
From the sounds of it you'll need to center your image in the family using the offset tools in the image editor popout window.
