How to perforate walls and slabs with copied shaft élements from linked model
1 ANTWORT 1
Nachricht 1 von 2
ahmad_bader-eddine
146 Aufrufe, 1 Antwort
hi all,
i tried so much to perforate walls and slabs in my model using the elements copied from a linked MEP model where the shafts are modeled as generic models under data devices family,
the problem that once copied it not  couldnt be assigned to the host automaticaly and should reassign to the wall host, and it's seems impossible to do that manually to all (have more than 1000 in the project).
I tried to use the command cut and create a script dynamo to automate that, but evec the command cut didnt work for all the cases, so the script didnt work.
if someone have a solution i will be thankfull
1 ANTWORT 1
Nachricht 2 von 2
You could copy-monitor the openings. The reason why they are "data devices" is because that is one of the categories that can be copy-monitored. I had to do the same in a recent project, I chose something else, "air terminals" to do my openings, for the same reason.
