how to override walls color and pattern inside a LINK?
11 ANTWORTEN 11
Nachricht 1 von 12
danezeq
2530 Aufrufe, 11 Antworten
Hey
I have a rvt link inside my project which is greyed.
I want to emphasize the WALLS inside that rvt link so they will be display on normal colour. (black. not halftoned and not grey)
So i did this (short video) but it fails -excapt one wall (what the?!)
Can someone explain me where is my mistake?
11 ANTWORTEN 11
Nachricht 2 von 12
ennujozlagam
als Antwort auf: danezeq
@danezeq Hello, I just replicate what you did, but not too sure if this is you wanted it to be. Thanks
Nachricht 3 von 12
danezeq
als Antwort auf: ennujozlagam
Thanks! your video helped me. you modified it under "cut" and not under "projection/surface" like me.
But i still cant get it to work beacuse i'm on MECHANICAL dicipline which halftone all the walls.
if i change diciplice to architectural, it works. i need to emphasize WALL only under MECHANICAL dicipline. how can it be done?
Nachricht 4 von 12
ennujozlagam
@danezeq hello, i really don't know if this one works for you, i just created a "view template" thanks
Nachricht 5 von 12
danezeq
You're still under archtectural dicipline!
Nachricht 6 von 12
The tricky part is that you must be in a View with Architecture or Coordination discipline when you link the Architectural model to your file.  After linking and override the Revit link as shown in the screencast below, you can change the View back to Mechanical and the graphics of the link will stick.
If you are under Mechanical discipline when linking.  The link graphic will be grey no matter how you override it, at least that from my personal experience.
Edit:  new screencast
Nachricht 7 von 12
RDAOU
@danezeq
did any of the good answers above resolve the walls issue you had?
Nachricht 8 von 12
danezeq
als Antwort auf: ToanDN
Ok i sucseeded doing your trick but only with new file.
it doest work on the existing file im working with.
i tried to remove the link and re link it when i'm on architectural dicipline.
Nachricht 9 von 12
RDAOU
@danezeq worksets in the linked model?
Nachricht 10 von 12
danezeq
als Antwort auf: RDAOU
No.
both of them dont have worksets at all.
Nachricht 11 von 12
danezeq
Nachricht 12 von 12
@danezeq you need to relink
