I have a host family that include 4 nested families A at 4 location, where optional to exist or not exist (eg 3 exist 1 not), and the volume should change accordling (eg only 3 is counted and deducted by 1), some like a door with or without 1 or 2 hinge or 1 or 3 handle
I had tried visibility but volume not affected. And adding a cut void parameter (cut to no-exist or not cut to exist) seens works -- but
is there any more direct parametric way to control the exist or non-exist of a nested family while volume can calculated accordingly?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Gelöst von heichan88. Gehe zur Lösung
If you are using generic models category, the volume would
@heichan88 wrote:Hello Toan,
and can the schedule can filter to include or exlude that opted nested family? ( by whcih parameter eg visibility or cut void or by label?)
Toan?
who is Toan?
If the Y/N visibility parameters are shared, then you can schedule those as well and control it from the schedule as well.
