I made a family (red) with complicated shape (cut by void), so this element (red) contains inside voids and solids.
Then in the project, this family inseted to a colum (yellow), so there will be a void with the same shape as this nested family (red), i.e a reversed void element cut inside the colume with all the inside void and solids be reversed (male to be female and vise versa)
That means this complex family ought to have two reversed function (void or solid /male or female) --- with the inside void/solid opts to be reverse
this is similar like "subtraction/intersection" of two morps, but in rfa how an elements be switched from void to be solid (now seems cannot opt from void back to solid).
This should often happens in MEP machine, like a screw inserted in to a part then a female void with same sape is created within this part.
That is too ambicious I understand, but much appreciate if any advice
