How to Not have Sectional Annotation Line Cut Through the Entire Plan?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
pearlofsadness
399 Aufrufe, 4 Antworten
Hi all,
I would like to know if it is possible to create a special Section Annotation Line that DOES NOT cut all the way through a plan? I would want it to cut Partially on the plan for annotation purposes on plan only. As I find it quite distracting when it cuts all the way through the plan. I would like to have it cut like this for example:
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: pearlofsadness
The function is built-in. Select a section line and click on the break symbol in the middle.
Nachricht 3 von 5
pearlofsadness
als Antwort auf: ToanDN
didn't realised it's there after months and months of using Revit!!! Thank u so much!! :leicht_lächelndes_Gesicht:
Nachricht 4 von 5
Nachricht 5 von 5
pearlofsadness
als Antwort auf: barthbradley
thank u too :leicht_lächelndes_Gesicht:
