How to Modify/Enlarge the size of the menus
scoutid
Observer Observer
scoutid
Observer
Observer
Good morning,
i want to know if there is a way to modify the size of every single menu of the program, because my monitor resolution is 1920x1080p so at that configuration every text, icon or menu looks so small that hurts my eyes, i can´t work really well if everything is so tiny. I´ve been looking around in so many tutorials and stuff but i couldn´t find the way to change that settings in particular. PLEASE HELP ME I NEED TO FINSISH MY ASSIGMENTE 😞
RobDraw
That is a common resolution. Are you on a small monitor?
Until you find an adequate solution, you can try lowering your resolution.
Rob
scoutid
Observer
Observer
I don´t think it should be consider as "small", it´s a 22" regular samsung monitor. So that preference or config, Revit does it automatically and can´t be changed ? 😞
j_smith_TCF
Like RobDraw suggested, open your Windows display settings and change the resolution to a lower setting.
Or maybe you need better glasses?
scoutid
Observer
Observer
ok, thnaks mates, i´ll try. Thanks for your replies.
