How to model wood screen lattice
8 REPLIES 8
Message 1 of 9
CT36801
620 Views, 8 Replies
CT36801
I tried using a curtain system but it seems to be way too computationally expensive.
Here is what I am trying to reproduce:
What's the best way to do this? need to show realistically in model.
it needs to sit behind the actual storefront system - view from inside:
8 REPLIES 8
Message 2 of 9
vitorbortoncello
in reply to: CT36801
vitorbortoncello
Message 3 of 9
Are you modeling it only for rendering purposes? If so, you can get a photorealistic appearance without modeling it.
Message 4 of 9
CT36801
in reply to: barthbradley
CT36801
Client wants to see the grid behind storefront glass in elevation. The rendering part is easy enough.
Message 5 of 9
BTW, Regarding your Curtain Wall: a 0'-1" Horizontal/Vertical Grid is ridiculously dense. Revit will likely throw an "excessive" error in protest.  But, even if Revit is able to create it, Revit AND the naked eye won't be able to see that kind of detail when viewing it from a suitable camera distance from the Wall.
Message 6 of 9
Use a Grid Surface Pattern.
....Viewing a 0'-1"x0'-1" Grid Surface Pattern behind Glass from 15'-0"
...from 30'-0":
...from 30'-0":
Message 7 of 9
CT36801
CT36801
I would love to go this route but I have orders. Going to give something like this a try:
Revit Tutorial (Day 99) - Parametric Perforated Panel Family (youtube.com)
Message 8 of 9
Pattern-Based Curtain Panel (using Curtain Panel Pattern Based.rft) on Divided Surface.  Google it.
Message 9 of 9
15-inch square Pattern-Based Curtain Panels:
