how to model slanted window surrounds?
premont
Community Visitor
premont
Community Visitor
Community Visitor
We have these slanted window headers. I'm at a complete loss for how to model them. Any help would be greatly appreciated!
RDAOU
@premont
Instead of the standard wall opening which u use in the window family, use a void extrusion which has a trapezoidal shape
If you those are curtain wall elements used as windows
  1. Edit the type and Uncheck automatically embeded
  2. Model an In-Place void to cut the wall with. Alternatively, if you have to many of them, you can model the cutting void in a window family or a Generic Wall Based or Face Based
For in-place voids, make sure to use the cut command before you finish the in-place family instance
azad.Nanva
you have some way to do it! i try to explain some of them.
you can use the component->Model in-Place :
like this :
or you can make the Generic Model Family (face or wall based) or normal Generic Model and change it to work plane-base ,this is depending on your experience:
in your case ,if i was, I use the family like this(that can work with Angle or Height):
My assumption is that you don't have any problem with red brick wall and you have many of them in the project.
handjonathan
Hi @premont
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @azad.Nanva @RDAOU helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
