& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Instead of the standard wall opening which u use in the window family, use a void extrusion which has a trapezoidal shape
If you those are curtain wall elements used as windows
For in-place voids, make sure to use the cut command before you finish the in-place family instance
you have some way to do it! i try to explain some of them.
you can use the component->Model in-Place :
like this :
This is a modal window.
Beginning of dialog window. Escape will cancel and close the window.
End of dialog window.
This is a modal window. This modal can be closed by pressing the Escape key or activating the close button.
or you can make the Generic Model Family (face or wall based) or normal Generic Model and change it to work plane-base ,this is depending on your experience:
in your case ,if i was, I use the family like this(that can work with Angle or Height):
My assumption is that you don't have any problem with red brick wall and you have many of them in the project.
Hi @premont
Thanks a lot for posting your question to the forums! Have the solutions suggested by @azad.Nanva @RDAOU helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
