How to model skirting boards - Different methods described
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi everybody,
I've recently come across three different methods to model skirting boards in Revit and wanted to share what I've found out with you, also in order to understand which is the best way to do it - if there is one?!?
Method 1 - Room Finishing add-on
We apply the skirting using the "Room Finishing" add-on.
PROS
- Easy and quick to model.
- You can tag the skirting (independently from the wall "applied" to).
- Easy and quick to schedule.
CONS
- Being the skirting an actual wall type, when it comes to net area calculation of the room, Revit will consider it as an actual wall and therefore subtract its thickness to the overall area. The best solution to get around this is to set the thickness of the wall used as a skirting as thin as possible (e.g. 1mm). Although we have to bear in mind that there will always be a slight difference between the actual area of the room and the one calculated. The difference is minimum though - we are talking about decimals.
- The skirting doesn't stop at the end of the door architrave but goes all the way through it until it reaches the actual door opening. There is a thread on this (https://forums.autodesk.com/t5/revit-architecture-forum/wall-sweep-and-reveal-set-back/m-p/9239164#M...) and nobody seems to have found a proper solution yet. Lots of suggestions about changing the value manually but none of them make the process smooth and automated as I'd like to.
Method 2.A - Wall Sweep (part of wall structure)
In this case we add the sweep to the structure of the wall type we are going to use for the skirting board.
PROS
- Being a sweep (and not a wall) it won't be counted in the room area calculations as it happens for the method 1 described above.
CONS
- Cannot be tagged. A specific keynote needs to be created instead.
- Cannot be scheduled independently from the wall hosting it. Big limit!
- Being hosted by a specific wall type, every time we need to use a different type of skirting we need to create a new wall type and associate the new sweep to it. Tedious and not very flexible. We end up having hundreds of wall types just because of differente skirting required.
- Same problem with the skirting not stopping at the door architrave as per method 1 described above.
Method 2.B - Wall Sweep (applied to wall manually)
In this case we add the sweep using the tool in the ribbon and therefore we don't need to edit the structure of the wall we are applying it to.
PROS
- It can be tagged (see CONS below).
CONS
- Can be applied only in elevation and 3d views (doesn't work in plan views).
- If we want to tag it we need to either divide in parts and then apply the tag to the sweep or apply a material and then tag by material and not by item. Another method is to apply a keynote.
The above is the summary of what I've found out so far. Please feel free to comment and give suggestions.
Cheers,
Gab
