Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hi everybody,
I've recently come across three different methods to model skirting boards in Revit and wanted to share what I've found out with you, also in order to understand which is the best way to do it - if there is one?!?
Method 1 - Room Finishing add-on
We apply the skirting using the "Room Finishing" add-on.
PROS
CONS
Method 2.A - Wall Sweep (part of wall structure)
In this case we add the sweep to the structure of the wall type we are going to use for the skirting board.
PROS
CONS
Method 2.B - Wall Sweep (applied to wall manually)
In this case we add the sweep using the tool in the ribbon and therefore we don't need to edit the structure of the wall we are applying it to.
PROS
CONS
The above is the summary of what I've found out so far. Please feel free to comment and give suggestions.
Cheers,
Gab
Good tip Tim, thanks. However, that is an instance parameter and therefore it has to be done for every single wall used as skirting. Kind of "select all and uncheck that box".
Hi Barth,
Thanks for your screen grab. I know the set back can be set up in the properties. However, once it's set it will always be the same value and if I need to change it I'd have to create a new type and do it manually.
What I am after is a way to get the wall (Room Finishing add-on method) or the sweep used to show the skirting board to update automatically, no matter the type of door architrave I use.
Yes, you are right @Anonymous. I kind of figured that would be your come back too. It would have been mine. Anyways, I just I throw it out in case you were unaware of it. It has a usefulness.
Hi Barth,
Any suggestion is always appreciated. That way of managing the set back is one of the first things I've tried to use but it turned out to be not very Revit-geeky-parametric 🙂
What I'm after is something that once set up (properly) the first time can be used no matter the shape/width of the door architrave. That could save a lot of time and also simplify the model not having to deal with multiple skirting board types.
I get it. I've been there too. I think your first post says it pretty accurately and completely. Amend it with a mention of the "Setback" parameter - and its limitations - and I think you've said all that can be said on the subject.
Hit the Idea Forum next. I'll support it.
