Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
how to model like this
10 REPLIES 10
Message 1 of 11
BIM_Dreamer
653 Views, 10 Replies
please help how to model like this. thank you
10 REPLIES 10
Message 2 of 11
allanWYTZN
in reply to: BIM_Dreamer
I would use solid sweep along a path.
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-E1A36DCB-C629-44BE-9400-2D02D13CF7F4
If you either follow the tutorial above or just google "Revit solid sweep tutorial" you should be able to work it out.
Message 3 of 11
BIM_Dreamer
in reply to: allanWYTZN
dude can you show me how?
Message 4 of 11
MVE1112
just click the link
Message 5 of 11
BIM_Dreamer
in reply to: MVE1112
it is not the one i need. see my screenshot posted.
Message 6 of 11
azad.Nanva
i don't have your dimensions, but this is normal way to make your model because you have a groove in your model,with out groove you should use Swept Blend.
Message 7 of 11
azad.Nanva
and this is your model with out groove in , I use some Reference Plane this is your choice to what you use:
Message 8 of 11
BIM_Dreamer
in reply to: azad.Nanva
BTW what software did you use for recording? thank you
Message 9 of 11
azad.Nanva
Snipping Tool from microsoft:
Message 10 of 11
It's a simple extrusion with two loops.
Message 11 of 11
azad.Nanva
in reply to: barthbradley
but it has angled cut.so i use the Sweep,if i use the normal Extrusion then i must use the Sweep Void on it to make the angled cut on it.
