How to model a loft-based wall
1 ANTWORT 1
Nachricht 1 von 2
georgetoneverland
375 Aufrufe, 1 Antwort
Hi!
I'm having trouble to model a wall generated from a loft modeled in Moi3D.
It would be possible to model it natively or do some trick to generate this wall from the imported model?
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: georgetoneverland
Model these forms as Masses and apply Wall by [Mass] Face  in the Project.
Can you export Moi3D to SAT or DWG?  If so, you can insert the SAT or DWG into an In-Place Mass Session to convert it to a Revit Mass.
