Hi all!
I'm trying to know the area of this surfaces..
For the moment I "built" a wall (1mm of thikness), the violet one, but it doesn't give me the true surface.
Is there a method that let me know the real surface of the masses (maybe on a schedule) ?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Paint the area with a material. Create a material take-off schedule and filter by that material (or by As Paint field = Yes).
Product documentation and help topics:
Create a Material Takeoff Schedule
How to find the area of paint within a Revit model
Applying a Material to the Face of an Element/ Paint tool
The video below demonstrates how to create a material take-off
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
I'm not able to obtain a populated scheduled. Just like appliyng material fo surfaces not happens. What the problem?
Thanks in advance
