I couldn't find an answer after searching this forum and the internet. I want to add elevation views to my floor plan sheet in a spot near where the view is located. My floor plan takes up the entire sheet so I don't have room to put it beside it and would rather not add another sheet. Maybe mask isn't the correct term to use in my search.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You can edit the shape of the floor plan viewport to leave room for the elevation view on the same sheet
I thought about that and tried it after seeing your reply and it works. I thought there might be a way to make the overlay viewport background solid. Thanks.
