Hi, I'm a student and new to Revit! My building has concealed gutters and the brickwork extends right up to the to upper roof line (over the fascia). How to I make this happen? Thanks
Here are two options. Look at the Top Constraint and Top Offset properties of each.
Thanks, I think the rafters notch onto the external wall meaning that corner of the brick makes an angle with the edge of the roof slates. Is it possible to model this?
Yes. You would need to set the height of the top of the wall accordingly. But you might be well served to have structural give it their blessing.
Like this?
Two separate roofs.
