How to make this kind of window family?
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
btx05
748 Aufrufe, 10 Antworten
Can anyone help me make this revit family or tell me the steps on how to do it?
10 ANTWORTEN 10
Nachricht 2 von 11
RDAOU
als Antwort auf: btx05
@btx05
Using a Window or a Door family Template...similar to the attached sample file from the German OOTB Library. Check it out and see if you can figure the concept and how to edit and modify to your need
Alternatively...Instead of using a standard Window/Door family ...A simpler approach is to model it using a curtain wall element (Watch GIF Below)
Nachricht 3 von 11
Nachricht 4 von 11
GHASEM_ARIYANI
als Antwort auf: RDAOU
@RDAOU
The curtain wall is not suitable for windows,Because it can not be used in Legend view.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Nachricht 5 von 11
als Antwort auf: GHASEM_ARIYANI
@GHASEM_ARIYANI wrote:
@RDAOU
That's not correct.
Nachricht 6 von 11
GHASEM_ARIYANI
als Antwort auf: barthbradley
:grinsendes_Gesicht_mit_lächelnden_Augen:
Nachricht 7 von 11
It wasn't meant to be humorous. Curtain Wall Windows can be included in Legends.
Nachricht 8 von 11
GHASEM_ARIYANI
Hello @btx05
Simple Window family creations.
Nachricht 9 von 11
GHASEM_ARIYANI
You did not understand what I meant. I said using a curtain wall instead of a window is not right.
Nachricht 10 von 11
I understood what you said. In fact, I quoted you.  Whether or not that's what you "meant" - or what you consider to be "right" - you stated an inaccuracy.
Nachricht 11 von 11
- Create a new family using Window family template (A) > draw ref planes and place dimension parameters > model the frame
- Find: a Hopper window family (b), a Casement window family (c), a Fixed window family (d)
- Edit (b) (c) (d) and change Width and Height dimensions to instance parameters
- Load the above window families (b) (c) (d) into (A) and place them in the frame > constrain them to ref planes
- Load (A) to you project
