How to make section name appear top not bottom?
8 ANTWORTEN 8
Nachricht 1 von 9
martins.logins2
508 Aufrufe, 8 Antworten
The name of section appears at bottom but I'd like to figure out how to make it appear at top. Thanks
I click to create nameI click to create nameIt appears bottom but I want it to appear at topIt appears bottom but I want it to appear at top
Beschriftungen (1)
8 ANTWORTEN 8
Nachricht 2 von 9
_Vijay
als Antwort auf: martins.logins2
Do you mean the detail name?
Nachricht 3 von 9
martins.logins2
als Antwort auf: _Vijay
Yes, believe so
Nachricht 4 von 9
bimscape
Just click (once) on the view (ie the section in this case) on the sheet- to select it. And with it selected, you can now drag the name (called the "View Title") up to the position you want.
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Nachricht 5 von 9
martins.logins2
als Antwort auf: bimscape
That's what I am usually doing and that takes extra unnecessery time. I was thinking how to make is a defualt when click it shows on top not bottom
Nachricht 6 von 9
bimscape
Would love to be proved wrong- but I think it's position is hard-coded in.
Kind regards,
Ian
Nachricht 7 von 9
lucdoucet_msdl
@_Vijay
Do you mean View Title Marks?  :zwinkerndes_Gesicht_mit_Zunge:
-luc
Nachricht 8 von 9
_Vijay
@martins.logins2  you need to move manually. There is other no others shartcut for this task. It's Revit API limitation.
Nachricht 9 von 9
amarkonathala
#1. Select the View title
#2. Move to Location Wherever U want
