Hi all,
When i work with a ramp (or even with a floor with a slope), I cannot find a 'good' way to make the 2 adjacents part (floor/ramp) having exactly the same length. My problem is I end up with an extra small sharp corner of ramp not correctly aligned with the floor.
Do you have something to suggest me to get everything aligned?
My only idea would be to extract the slope angle, and then multiply ramp thickness by the cosinus of the angle
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Thanks for the reply. I'll try to create a patch and join it.
(This is a revit model for a FEA analysis, and the mesh generation process fails if tiny sharp edges exist in the model)
