How to make grid bubble to both sides and how to renumbered it in correct from 1 to n....
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
WEISMAT
1729 Aufrufe, 2 Antworten
I have a grid and inserted a vertical grid line that does not correspond to the first number.
1.) How can I add the bubbles [with number inside] to both sides.
2.) How can I put the numbers / numbers in the correct order. E.g. if my model has the sequence 11, 1, 2, 3, instead of
1, 2, .... 11
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: WEISMAT
A grid has two square boxes at both ends, tick them to turn on the bubbles.
Nachricht 3 von 3
martijn_pater
Draw them right to left or adjust the numbering manually.
