How to make curtain wall showing proper size in door schedule?
7 ANTWORTEN 7
Nachricht 1 von 8
shasha_nz
1349 Aufrufe, 7 Antworten
I have added an automatic sliding curtain wall door to my curtain wall panel, but when I try to create a door schedule the curtain wall door won't show the correct size (Plan view + Elevation Front view on the schedule), I tried to change the host length but the door height will change as well. There's no option for adjusting any parameter in the edit type, can anyone please help?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: shasha_nz
Add curtain grids and dimension them to create the correct curtain panel size, then change the panel to the curtain wall door.
Nachricht 3 von 8
shasha_nz
als Antwort auf: ToanDN
it's a 4 panel automatic sliding door. I can only add this door on a single curtain wall panel, how can I add grids? If I add grids it will change to 4 panels, which I could not change into one 4 panel door. And I need to dimension the height and width of the door on the schedule.
Sorry if I sound silly, just a beginner at this. Thanks.
Nachricht 4 von 8
Nachricht 5 von 8
Lachlan-JWP
A curtain panel does not have any width or height parameters that can be changed like with a standard door family. This is instead controlled by the size of the curtain wall panel that the door will replace. This can be controlled by changing the locations of the curtain wall grids or the overall size of the curtain wall itself.
To get the width & height of the door to appear in a schedule you may need to create an instance reporting parameter in the family that you recall in the schedule.
Nachricht 6 von 8
Nachricht 7 von 8
shasha_nz
als Antwort auf: Lachlan-JWP
Got it, thanks. My friend suggested me to choose a similar type of normal door into the door schedule to represent that particular curtain wall door.
Nachricht 8 von 8
No you don't need to do that.  A door schedule can show both normal doors and curtain wall doors.
