How to make curtain wall glass panel opaque in elevation view with realistic
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
na1257
469 Aufrufe, 1 Antwort
Hi all,
So I want to make the glass panels on my façade opaque, however it needs to be in realistic view.
I have changed the parameters on the glass panel itself to make it opaque, and this is only visible when I render, all other views are transparent.
1 ANTWORT 1
Nachricht 2 von 2
RDAOU
als Antwort auf: na1257
@na1257
Not at a workstation atm to check...but assuming you already did the following already and did not work
  1. Unchecked / Removed transparency under Graphics tab
  2. Used a Material (based on a Generic Appearance Asset) and removed transparency under Appearance too
Did you try to override graphics of curtain panels category and give a solid surface pattern?
