How to make a sloped, curved glass roof?
I am trying to make a revit model based off a rhino model. How can i create a framing system (the red lines in the third image) to connect the roof to the curtain walls?
Thank you 🙂
Sloping Glass Model (Rhino)Sloping Glass Model (Rhino)(Rhino)(Rhino)Revit Model (proposed beams in red)Revit Model (proposed beams in red)
Are they beams? Use Beam then.  Check 3D Snapping.
Yes, however i am unable to snap to the roof
constantin.stroescu
I'd use a Mass Element and then a Curtain System on on Face..as in my example
If you import a .sat file into Mass editor ,I think you will be able to snap on faces ....
https://knowledge.autodesk.com/community/screencast/ece0b7da-d1e5-477b-be0c-82a03c3923b1
Constantin Stroescu
Thank you!
