How can I make this kind of roof ??
Thankssssss
Thanks for your reply but I am not trying to make a tube shape
wanna make like bottom part of the roof slapped
or use Voids either as Model in Place or Editable Families..
Constantin Stroescu
You can use Floor: Slab Edge with a triangle as profile.
You can try with the attached profile.
Floor: Slab Edge - Edit Type - Duplicate...
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Sorry, I noticed you said "Roof"
You can do the same using "Roof: Fascia"
After you place Fascia, you have to join Roof with Fascia.
Kostas Kouris
@kagosw0314 wrote:I cant edit the profile of fascia?
After loading (Import - Load Family) the profile you can edit it from Project Browser - Families - Profiles.
Find the profile, expand, right click and choose Type Properties...
You can edit both width and height separately.
Kostas Kouris
@kagosw0314 wrote:I should say i cant join them tgt
I describe from beginning all the steps.
1. You have already design the Roof
2. Tab Architecture - Roof: Fascia
3. Select the edge or Tab and select to select the perimeter
4. Tab Modify - Join - Join Geometry
5. Click the Roof and the Fascia (the order doesn't matter)
6. Roof and Fascia must have the same material.
Kostas Kouris
