How to make 2 options in an option set visible in a view
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
2111 Aufrufe, 7 Antworten
In my model I set up 3 options in 1 option set:
Option Set1:
Option: Library full alterations (primary)
Option: New Building
Option: Existing Library
The visibility I need is:
1. All 3 options visible. Now I know under the view properties there is under 'Visibility in option' an option 'all', but this doesn't change anything in the view. It simply stays with whatever the last Option was I chose, eg Option: New Building
2. Then I also need to sometimes see two of the options together in a view. Is this possible?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
Do you want both options visible in the same view?
Or do you want two views, each one representing each option?
Nachricht 3 von 8
I need to see 2 or even 3 options in the same view. Eg. Option 1 and 2 or
option 2and 3 or option 1 and 3 or Option 1 and 2 and 3
Nachricht 4 von 8
Create one view for each option and put them on top of each others on a Sheet. When you activate a view of one option, you can still see the others in the background, albeit blurry.
Nachricht 5 von 8
Alfredo_Medina
Option Set1:
1. All 3 options visible....
Welcome to the forum.
I think you are misunderstanding the usage of Design Options. Options are supposed to be alternatives of the same thing, which means that option 1 replaces option 2, and viceversa. If what you need is 3 different things at the same time, what you need is 3 Options Sets, each of them with at least 2 options. Then, you can combine the option sets in multiple ways.
For example:
Option Set Roof
         Roof option 1, Roof option 2, Roof option 3
Option Set Entrance
        Entrance option 1, Entrance option 2, Entrance option 3
Option Patio
         Patio option 1, Patio option 2, Patio option 3
Then, using view templates, you can create "Models" (using the term as in the real state business), for example:
Model "Venezia" : Roof option 1 + Entrance option 2 + Patio Option 1
Model "Rome" : Roof option 2 + Entrance option 3 + Entrance option 2.
etc..., etc. as many model combinations are possible.
Nachricht 6 von 8
als Antwort auf: ToanDN
I wont be able to join walls and dimension between options
Nachricht 7 von 8
als Antwort auf: Alfredo_Medina
Ok, so I just need to split my current options that is in one option set,
into different option sets?
Before I move everything around, I just need to know if I can have 2
different options from 2 different option sets visible in the same view?
Nachricht 8 von 8
Alfredo_Medina
Of course, that is what I explained above, creating "models" of options, with view templates.
