is there any way to create a parameter that allows a window to always come in at a certain head height by possibly creating a "head height" distance to the parameters dialog, and then subtracting the window height from this head height number to then set the "sill height" parameter automatically?
That would always keep your window head height the same if you change window sizes...
Is this possible?
John
Of course it is very possible.
You can either lock by entering a value inside the formula column
Or enter a formula to calculate the sill height according to the top height!
Revit is amazing in that way!
Francois-Gabriel Perraudin
BIM management and coaching
