How to lock family in Revit model to avoid someone else can edit or re-use ?
@EmptySaturnV Hello, you cannot lock families in Revit at this time. BIM is a coordination and sharing. Thanks
You can't lock a family, BUT, You can lock a family workset, so other will not be able to modify them.
Simply make the families workset editable, and don't relinquish that workset.
As attached files , they lock family and create warning for Revit
My customer doesn't want to use IFC or something like that. They just want to lock family
Revit is for sharing community and environment but some exceptions require copyright. That's point
Currently there are no lock or password options in Revit.
If you want to send a model to a client it's an all or nothing scenario: either they get an IFC/DWG which can't be edited or they get a Revit file.
Locking Worksets or Design Options only "locks" (detaching the project and resaving the project makes the worksets editable again), one can still save the families used in the project.
This attached family appears to be locked so there must be a way to do this.
hello, what do you mean locked its a family, edit your family to modify. thanks
sorry double post.
Not sure that the earlier post got through but the nested families in the attached dining table cannot be edited so there might be a way to lock families.
Hi, and yes the main family can be opened. However the nested families inside are somehow locked and cannot be edited.
refer to this LINK previous threads. thanks
@architerio Did you find a solution or an explanation? How were nested families locked?
