how to layering ("subcategory") many Divided Suafaces
7 ANTWORTEN 7
Nachricht 1 von 8
heichan88
302 Aufrufe, 7 Antworten
hello,
i have a roof with many layers of Divided Suafaces (roof sheet, lower joist, mid joist, upper joist, tile), in difference ,
i want to make them layers to turn on and off, but no category can define  Divided surface.
How to define subcategory for divided surface to turn it on and off?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: heichan88
You know you can change the VGOs of tiles individually or collectively; right?
Nachricht 3 von 8
Do you mean you want to turn on off components created by different divided surfaces independently?
Nachricht 4 von 8
heichan88
als Antwort auf: ToanDN
hello @ToanDN ]
yes,
the form have "subcategory", but divided surface" don't have this option to turn it on or off
the patern can be opt to tile or blank, but the "divided surface" can not be on or off in VGO, but just "temporary hide/unhide",
Nachricht 5 von 8
heichan88
OK I
turn off the pattern surface, then with tile turn off, the whole turn off also,
Nachricht 6 von 8
heichan88
Sorry I still cannot find how to "turn off" the devided surfaces as if they are "layer" or "subcategory".
I have many devided surface on the same form off roof (joist, sheeting, tiles etc) so I need to selectively turn off these devided fur faces. If only "temporary turn" off is still a mess
Please advice
Nachricht 7 von 8
Nachricht 8 von 8
heichan88
als Antwort auf: barthbradley
hello @barthbradley
My intention is to make many divided surfaces turn off or on like "subcategory" or "layer",
seems current RVT version not have this function, ie no way to opt to turn-on-off excpt "temporary turn off"
