How do I know when my furniture is the correct way around when I am in plan view?
Without having to switch to the elevation or section..
Is there a way I can make a reference to the front, back and sides?
Aidan
You can draw annotation lines in the family that can help you in plan views. They won't appear in 3d or sections/elevations
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
What @rxi.gg was saying or:
-Add something in the family with a visibility (type) parameter which you can switch off when not needed anymore.
-Add something in the family under a special sub-category which you can hide.
-Or have multiple views open (plan and 3D view) so you can see in 3D how you are placing elements while working in plan view.
-Work in wireframe mode
Louis
Please mention Revit version, especially when uploading Revit files.
