How to keep Swept Blend's prfiles Vertical ??
15 ANTWORTEN 15
GELÖST
Nachricht 1 von 16
000853959
895 Aufrufe, 15 Antworten
Hello Folks:
when creating Swept Blend..
How Can you keep Swept Blend profiles vertical but not perpendicular to the path?? any suggestions?
15 ANTWORTEN 15
Nachricht 2 von 16
als Antwort auf: 000853959
Huh?
Got a picture of what you want to model in Revit?
Nachricht 3 von 16
000853959
I already attached the image I just need the profiles as shown in the picture, any idea please?
Nachricht 4 von 16
I want to see a photograph of the architectural feature (or whatever it is) that you are trying to model in Revit with a sweep. I don't understand your written description or screenshot.  Doesn't look like anybody else does either, since you've had no responses.
Nachricht 5 von 16
Use an adaptive generic model family with nested profile families that are set to be always vertical.
Nachricht 6 von 16
Maybe this is what you are after?
Nachricht 7 von 16
Oops. You said Sweep Blend. Not Sweep. My bad.
Vertical VS Perpendicular:
Vertical AND Perpendicular - just for fun:
Nachricht 8 von 16
000853959
als Antwort auf: barthbradley
Iam trying to model Ramp with inverted beams on both sides as shown in the picture, I need the family category to be "Structural framing" so I can host rebar, However I need the profile of the swept blend to be perpendicular to the Ground, I dont have an option to control the angle between profile and ground. sorry I know my language is not that good I hope I could explain my point
All options grayed out except first one! why?!
Nachricht 9 von 16
000853959
als Antwort auf: ToanDN
it might be a solution but not long term especially if you want to modify the model, it would waste much time, thank you though
Nachricht 10 von 16
000853959
How come your profiles here (in the picture you attached for swept blend ) are not perpendicular to the Path??
Nachricht 11 von 16
in the real world, a beam running along the underside of a ramp (e.g. at an angle to ground level) does not remain perpendicular to the level ground below. That doesn't even make sense.   That's why I asked to see a photograph.
Also, why are you using a SWEEP BLEND?
FWIW:
Nachricht 12 von 16
000853959
Nachricht 13 von 16
000853959
Can you model this?
Nachricht 14 von 16
Sure. I would cut the ends vertically and perpendicular to ground.  Bada bing.
Post your file here.
Nachricht 15 von 16
- Start a swept blend
- Draw the path using one spline on the level
- Draw the start profile at starting point of the spline
- Draw the end profile at end point of the profile move it vertically
(if you use a loaded profile family then you can simply set Vertical offset from properties)
Nachricht 16 von 16
000853959
Perfect! thank you, copy the profile and Offset from the prfile it self, simple! thanks dude
I've been picking the the path instead, that was my mistake
