I have this geometry centered on a reference plane, with a 'Thickness' parameter applied.
When I change the dimension, it changes in one direction only, and it's no longer centered on the reference plane. Is there a way to change the geometry from the center?
Thank you! So I have three dimensions, one for the parameter, and two x EQ.
yes, it's preferable to dimension the Reference Planes and the element borders to be locked on them..
Constantin Stroescu
