How to join Baluster to Top rail & some other...
7 ANTWORTEN 7
Nachricht 1 von 8
Ali.Katebi
2008 Aufrufe, 7 Antworten
Hello
I uploaded some pictures to describe my issue.
I should draw this railing (Picture 1):
1- The first baluster can't join to top railing correctly. (2)
2- Some railings and the first baluster are overlapped. (3)
3- The top railing is not shown correctly. (4)
4- It is necessary to cut the railing vertically. (5)
I showed railing settings. (6)
Revit file attached.
Beschriftungen (1)
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Ali.Katebi
Change your Post Spacing.
Nachricht 3 von 8
Looks like you don't want to use a Post. Looks like you want the "Posts" to meet and taper to the Top Rail.  Swap out the Posts for Balusters that have that intelligence built into them.
Nachricht 4 von 8
Ali.Katebi
als Antwort auf: barthbradley
Could you show my issue with some screenshots in Revit that how can I solve it?
I have to reach to picture 1.jpg, it is not important in what way.
Thank you
Nachricht 5 von 8
I'm referring to the Start Post at the first Tread.  If you want the top of it to have the same cut angle that the Balusters have, then you need to just swap out your Post for a Baluster of the same dimensions.   Understand?
Nachricht 6 von 8
Ali.Katebi
Yes, I solved it. Thanks.
But My problems remain. If you see picture attached, number 3,4 & 5 remain.
Picture attached again
Nachricht 7 von 8
I wouldn't model it -- or build it -- the way you are showing.  I would do it like is shown in your very first screenshot.
Nachricht 8 von 8
Ali.Katebi
OK. Anyway, thank you for your response.
