How to install ceiling families?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
4741 Aufrufe, 3 Antworten
Although there are so many ceiling families available for download at Bimobject.com however most of them in aren't rfa files.
So how exactly am i supposed to install them?
For example
3 ANTWORTEN 3
Nachricht 2 von 4
Revit_Whisperer
als Antwort auf: Anonymous
Those first four look like rfa files...but the rest are Revit project files it looks like, and since Ceilings are a system family, you would have to use either transfer project standards or copy to clipboard to get them into your project.
To use either of those you need to have both projects open in the same session of Revit.
Nachricht 3 von 4
Sahay_R
That is because they may have been developed as Ceiling types (Edit Type>>Duplicate>>Rename and then customize).
Open the ceiling file in the same session as your project. CTRL-C the ceiling, CTRL-V into your destination project. That should drop the ceiling type into your project.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 4 von 4
...first, download a ladder family that is tall enough for you to reach the ceiling.
