HOW TO INSERT GLASS PANEL INTO THE CUT HOLE? building is in curvy form* steps for solution are much appreciated,thank you~
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
hwangt0412
278 Aufrufe, 4 Antworten
Tags (1)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: hwangt0412
For 3D and elevations:
- make an exact copy of the solid wall, without the holes, place in the same place
- change to a glass wall type
If you want to cut the glass to the exact holes then it is a bit more involved.  If you need to do that then let us know.
Nachricht 3 von 5
hwangt0412
als Antwort auf: ToanDN
would you mind sharing me in video form for that please?since im not so familiar w revit TT thank you so much for that~
Nachricht 4 von 5
Nachricht 5 von 5
hwangt0412
thank you so so muchh againnnnn!!!
