how to insert and work with world coordinate Rcs (point cloud) data .
venkey756
Message 1 of 11
venkey756
I have tried to insert this data  in (origin to origin) but  it was visible at far away  and which we cannot work.
and also i have tried to insert the data in ( centre to centre ) and it worked but when i remove and reinsert the data its changing its position and each and every time  when i load it as new . and its not matching with Autocad coordinates as well.
 for shared coordinates also i am getting same warning
any one help in solving this issue.
Replies (10)
Message 2 of 11
Just move/reposition your Point Cloud to where it should be relative to your Building Model.
Message 3 of 11
venkey756
If we move the point cloud manually  the world coordinates may change
We can't use this model
Is there any alternate solution  for this issue
Message 4 of 11
Huh?  That doesn't make any sense.  What do you mean by this?
Message 5 of 11
- Insert the point cloud in a blank Revit project, add a couple of location identifier such as grid lines
- Link this project to your project, move it to align with you model using the linked location identifier
- Acquire the link coordinates
Message 6 of 11
That won't work either.  The Point Cloud will insert into a blank Project the same way -- well beyond the maximum allowed limit.
The solution is to move the Point Cloud to where it need to be in the Building Model Project.  Period.
Message 7 of 11
@venkey756 :
Don't worry about real world coordinates. Just place your Point Cloud where it needs to be in relationship to the Building Model -- or very close to the Internal Origin of the Project if you haven't started modeling the building yet.  You can always locate the Project to "real world coordinates" later.
Message 8 of 11
jkarben
If there are multiple point clouds start by linking them origin-to-origin. That should keep there position correct between them. Group them. Move the group into position with the Revit model. When you get point cloud updates do a reload from in lieu of removing and re-adding.
Message 9 of 11
Corsten.Au
Hello
see if this helps.
https://knowledge.autodesk.com/support/recap/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-The-coordinates-of-the-points-in-the-point-cloud-file-s-you-are-trying-to-import-are-larger-than-30000-in-when-inserting-a-point-cloud-in-Revit.html
https://forums.autodesk.com/t5/revit-architecture-forum/the-coordinates-of-the-points-in-the-point-c...
Corsten
Building Designer
Message 10 of 11
venkey756
Thank you for your reply i have already found a solution
Message 11 of 11
Out of curiosity, what was your solution?
