How to include a column for "comments" in the revision schedule
10 ANTWORTEN 10
Nachricht 1 von 11
4181 Aufrufe, 10 Antworten
There are MARK and COMMENTS in the Properties box, but how do we include these into the revision schedule? There is no option to create a new parameter.
10 ANTWORTEN 10
Nachricht 2 von 11
L.Maas
als Antwort auf: Anonymous
Correct. Unfortunately it is not possible to extend the revision schedule. The only possible option is to use use one of the other columns (if not all in use already) for your purposes.
Maybe good to support one of the proposals in the IDEAS forum, like THIS one.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 11
Mikael_QUIJADA
als Antwort auf: L.Maas
It's not possible natively but you can use this dynamo script :leicht_lächelndes_Gesicht:
It's in french but change
"Nuages de révisions" by  "Revision Clouds"
"Commantaires" by "Comments"
"Nuages" by "Clouds"
You must dowload Clockwork package
Mikaël QUIJADA
Accompagnement personnalisé Revit Structure
Projeteur Structure indépendant
www.strall.fr
Nachricht 4 von 11
als Antwort auf: Mikael_QUIJADA
Hey man,
I need to get this working, for some reason I get some errors running the script you provided in dynamo, would you give a more detail workflow of this and what needs to be done before hand ?
I much appreciate it.
Nachricht 5 von 11
Have you been able to fix this problem ?
I'm asking since I'm having the same issue with revit revision cloud.
If you have found the solution for this, please kindly share with me.
Nachricht 6 von 11
Mikael_QUIJADA
Hi guy,
Can you give me more details abouts this errors ?
Have you dowload Clockwork package in Dynamo ?
Mikaël QUIJADA
www.strall.fr
Nachricht 7 von 11
Thanks for the prompt response,
yes I have downloaded clockwork and dragged it into canvas in Dynamo,
This is the error I receive, as shown in the picture below,
what do I need to do to fix this ?
Iman
Nachricht 8 von 11
Mikael_QUIJADA
Ok the problem come from clockwork.
Download Dynamo 0.9.1 > http://dyn-builds-data.s3-us-west-2.amazonaws.com/DynamoInstall0.9.1.exe on http://dynamobuilds.com/
Download clockwork package 0.9.x version.
it should work better.
Mikaël QUIJADA
www.strall.fr
Nachricht 9 von 11
Cool, I guess it's time to start DYNAMO. Verlegener Smiley
Nachricht 10 von 11
Hello, thanks for the tips with the export to Excel function!
I wonder - why is it necessary to include the owner views in the transposition?
Wouldn't just the number of elements and the parameter name be enough?
//Kalo
Nachricht 11 von 11
isaac.e.hartman
Christ, this is stupid. Why include a COMMENTS section in the revision properties at all? It's purely internal? Why don't Revision Schedules just work like any other schedule in the program?
AutoDesk, if you're going to charge $5K/year for a program, how about you tie up a few of the loose threads?
