How to important Revit into CAD with its parameters and set of standards
1 ANTWORT 1
Nachricht 1 von 2
jgarciacorpus69
135 Aufrufe, 1 Antwort
Does anyone know how to import some revit models into cad with its settings and parameters?
1 ANTWORT 1
Nachricht 2 von 2
aruckerY7D6L
als Antwort auf: jgarciacorpus69
What settings and parameters are you trying to bring over? I have tried this and only way I was able to get it to work was by converting everything (duct in my case) to CADmep database items (https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revit-M...) then export as a DWG with the Revit Extension for Fabrication. This kept some of the parameters but not everything.
I was pulled off that project though before I could do much more than this so I am interested how this works for you and/or what others have came up with.
