How to import 3ds file into revit?
danezeq
danezeq
i dont find any option to import 3ds files into revit. should i first convert the 3ds to 3d-dwg file?
Replies (7)
Viveka_CD
Autodesk Support
Autodesk Support
Hi @danezeq
Please see similar post HERE  and HERE on import options.
Let me know if you have any questions.
Sahay_R
The short answer is - very painfully.
Your best option would be to import into a Revit family of the correct category. In the Family Editor -
Insert>>Import CAD
Export your 3DS geometry to a SAT or DXF first.
Since 3DS geometry will come in a one single object, it would be a good idea for you to split it up into parts - for instance, for a chair have one file with the legs, another with the set, the third with the back, and import them into separate Revit families that can then be nested into one single chair family. It will also make it easier to assign material parameters.
Please remember - what you will get at the end of this process will be 'dumb' geometry. You will not be able to apply dimensional parameters, types, etc to the family.
Final note - the only situation where modeling in 3DS Max would score over modeling in Revit would be in the case of complex geometry which curves in three or more directions. As far as possible - modeling in Revit would allow you to control the geometry using parameters.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
danezeq
Thank you for your answers.
so i understand i must first convert it to dwg via 3dsmax.
Sahay_R
Yes. Split the object up into separate files (if possible / needed). Export to DXF. Import into Revit family. Nest all parts into another Revit family. You should be fine.
Rina Sahay
danezeq
Thank you!
Sahay_R
Please Accept the solution so that others can find it.
Rina Sahay
karenjane_fernandez
Observer
Observer
how to convert 3ds file into revit family? i don't have the 3ds software. can someone here help me to convert it? please thank you
