how to hide the magenta line in the middle of the beams?
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
615148142
413 Aufrufe, 6 Antworten
hi  I am new to revit and i have a question: how to get rid of the magenta/pink line in the middle of the beams? I try to find it in VG settings, but can not find it. I also tried Structural settings, and cannot find either. Could you please help me?   Please see the attached image.
6 ANTWORTEN 6
Nachricht 2 von 7
alan.johnson7YLND
als Antwort auf: 615148142
What version of Revit are you using?
What type of Beam is it?
Have you got a view template applied?
Have you got something selected or Are you editing something?
Can you share your model?
Nachricht 3 von 7
615148142
als Antwort auf: alan.johnson7YLND
hi i am using Revit 2023 but I remember there was this magenta line in the middle of beams when i use 2022.
It is a normal timber beam I loaded from the Autodesl Revit library. I when into the family editor and the magenta line is in the family. I cannot get rid of it in the family editor either.
There is no view template . I am not editing anything. and there is nothing selected.
I just drew the beam from menu:  Structure --- Beam.
Nachricht 4 von 7
alan.johnson7YLND
I have just tested in Revit 2023 with a timber beam and there is no magenta line in the centre of my beam.
Strange
Is it possible to share your model?
Nachricht 5 von 7
615148142
hi thank you so much for your help!  please see the attached family file, you can see the magenta line,
Nachricht 6 von 7
alan.johnson7YLND
Ok there is a Foreground surface pattern applied which is magenta lines.
Set that to none and the magenta line will be gone.
Nachricht 7 von 7
615148142
yes that's it. Thank you so much!
