How to hide project base point and elevation point
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
11500 Aufrufe, 4 Antworten
I have the project base point and elevation point randomly popping up in two interior elevations - how can I hide them? Don;t see anything in visibility graphics unless I'm looking for the wrong thing....
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Expanding the Site category. They are in there.
Nachricht 3 von 5
als Antwort auf: ToanDN
Revit 2020 - for some reason these are still showing up greyed back. This creates issues when placing plan views on sheets whether view extents are controlled by scope boxes or not - the view extents now include these points, so when the view is placed and your points are 4 miles away, you need to find the content of your view, which is sometimes not visible when zoomed to extents, then move the view where you want it which is difficult because you now see the whole earth, then try and find the title and move that to the right spot. This takes alot of time when doing a sheet full of elevator plans. Why was this changed for 2020??? This is NOT a good change! https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...
Nachricht 4 von 5
RobDraw
It wasn't intentional, I'm sure, and it only affects existing projects. New projects will not have the base points visible.
Rob
Nachricht 5 von 5
pnbaldwin
Thank you for the simple response.
I would like to add that you can control the visibility with a View Template....navigate to the view template, then edit the V/G Overides Model, then navigate to the site visibility and it is in there.
