AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
How to hide multiple slab edges.
5 ANTWORTEN 5
Nachricht 1 von 6
3021 Aufrufe, 5 Antworten
Although you can just hide slab edges in elevation by using line work>invisible line. But It's a time consuming processes if your project is big. Is there  a faster way to hide them?
5 ANTWORTEN 5
Nachricht 2 von 6
d.avalishvili
als Antwort auf: Anonymous
in VG uncheck slab edges :leicht_lƤchelndes_Gesicht:
Nachricht 3 von 6
...also you can create a View Template that includes the VG setting that @d.avalishvili showed, and then apply that View Template to existing or new view which you want to use those settings.
Nachricht 4 von 6
als Antwort auf: d.avalishvili
Strange.I followed what you said and unchecked slab edges from the visibility overdrives but it still shows the slab edge.Capture.JPG
Nachricht 5 von 6
d.avalishvili
if you mean horizontal lines i think they are not slab edges. they are just slab lines.
Nachricht 6 von 6
d.avalishvili
if you want to hide slabs you have to add finishing layer to your wall.
see example. green layer. in this case you wont see slab lines.
In Foren verƶffentlichen
