Is there a way to hide only one Icon in the ribbon bar, for istance the Dynamo program?
I'd like to limit the use of Dynamo to some of the users, letting them only use Dynamo Player.
Thanks for all your help,
Carmine
Gelöst! Gehe zur Lösung
Gelöst von loboarch. Gehe zur Lösung
I don't think it's possible unless you have a background in programming/C#. Thanks
You can't hide the Dynamo button, but it is possible to intercept the press of the dynamo button to do something else, or prompt a warning or instructional dialog. Of course you need some API knowledge to make an add-in that can do this.
