How to Hide at Scales 1:50
I'm try to hide at scale 1:50 my section tags?
www.TechRoom.bg
Sure, you can go in and hide each tag that you do not want to see, but that takes a lot of time.  Instead, select your wall section, then go to ‘Hide at Scales Coarser Than’ under properties and change the scale.  Think of this as ‘Hide at Scales SMALLER than’ – this pull down tells Revit not to display this tag on any views that are set to a scale that will print smaller than the scale you pick here.  If you set ‘Hide at Scales Coarser Than’ to 1/8″=1′-0″, then this tag will be visible on your 1/8″=1′-0″ scale views, but will automatically be hidden on your 1/16″=1′-0″, 3/32=1′-0″, etc. views.
If you have a section/elevation mark that should be showing up on a small-scale view, but it’s missing even when you use the light bulb, find the view in your project browser and double check this setting.  It may accidentally be set to a large scale, which basically hides it everywhere.
Revit Hide at Scales Coarser Than.fw
I hope this will help you!
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
