How can i select scope box in order to edit it's size NOT ON 3D VIEW?
well, you need to see it before you can grab it. Grab it in 3D and set is to be visible in the view that what to size it.
Here is why you CAN'T see it in a plan view or elevation view or whatever... Because when you associated the view to the scope box, the view's crop region got turned on and sized exactly to the borders of that scope box.
So the solution is to turn off the view cropping, adjust the scope box, and then turn the cropping back on.
That all assumes you haven't also hidden the scope box.
thanks for the answers.
1. i see it on 3d view and on "views visible" i can see it's already visible in my disaierd view.
2.i canceled the association to the scope box in that view and cancel the crop view option.
3. scope box is VISIBLE on VV window. it's not hidden.
and still! i cannot see the scope box in that view!
BTW i can see another 2 scope box in that view...
i think the problem was i didnt notice that scope boxes are 3d, i changed the height of the scopebox.
That's exactly what @chrisplyler said; "Maybe the view range doesn't intersect the scope box." Give the man a cigar!
am sure your problem is solved already..
Just another thing is , It good to " Rename " scope boxes "
so its easy to use
Ex : ScopeBox - block A
Scope Box - for A1 Sheet
ScopeBox-Shadow Diagrams
etc..
you can use these in view template to get exact consistent views..
Cheers!
